Raspberry Pi
Controlling a DC Motor with Raspberry Pi4
June 04, 2020 by Mr. Sarful hassan
In this tutorial, I will show you how to connect some motors to your Raspberry Pi4.
Introduction
In this tutorial, I will show you how to connect some motors to your Raspberry Pi4. DC Motor with Raspberry Pi lies with the Motor Driver.
What is motor Driver: A Motor Driver is a special circuit or IC that provides the necessary power (or rather the current) to the motor for smooth and safe operation.
we should never connect a motor directly to Raspberry Pi
Components Required
  1. Raspberry Pi 4 Model B
  2. L298N Motor Driver Module
  3. Lipo Battery 3300mAh
  4. Connecting wires (Jumper Wires)
  5. 5V – 2A Power Supply for Raspberry Pi
  6. 5V DC Motor
Circuit Diagram
import RPi.GPIO as GPIO
from time import sleep
# Pins for Motor Driver Inputs
Motor1A = 21
Motor1B = 20
Motor1E = 16
def setup():
    GPIO.setwarnings(False)
    GPIO.setmode(GPIO.BCM)              # GPIO Numbering
    GPIO.setup(Motor1A,GPIO.OUT)  # All pins as Outputs
    GPIO.setup(Motor1B,GPIO.OUT)
    GPIO.setup(Motor1E,GPIO.OUT)
def loop():
    # Going forwards
    GPIO.output(Motor1A,GPIO.HIGH)
    GPIO.output(Motor1B,GPIO.LOW)
    GPIO.output(Motor1E,GPIO.HIGH)
    print("Going forwards")
    sleep(5)
    # Going backwards
    GPIO.output(Motor1A,GPIO.LOW)
    GPIO.output(Motor1B,GPIO.HIGH)
    print("Going backwards")
    sleep(5)
    # Stop
    GPIO.output(Motor1E,GPIO.LOW)
    print("Stop")
def destroy():
    GPIO.cleanup()
if __name__ == '__main__':     # Program start from here
    setup()
    try:
            loop()
    except KeyboardInterrupt:
        destroy()
Mr. Sarful hassan
Love #python #raspberrypi #ardunio #Electronics
