Zenith TV 1994 model SM2568S picture compressed
Jacques Carrier
Hi fellow techs,
This 1994 25" Zenith TV model SM2568S has a complete picture which
occupies
about 40% of the CRT face plate.The picture is compressed and centered
about
the middle of the screen.(Wide black bar on top and wide black bar on
the bottom)
My coworker has a 1995 27" Zenith TV with the exact same problem.
Sometimes I get the full picture with 2 fine horizontal lines in the
middle.
All the caps around the vertical IC are OK.(ESR OK)The vertical IC
LA7838 has been resoldered.Is there something else I need to check
before I grab the scope?
Best regards,
Jacques
K
Ken
Jacques said:
Hi fellow techs,
occupies
about
the bottom)
middle.
Best regards,
Jacques
I believe I have the same set, and once encountered the same problem.
Unfortunately I too changed the vertical IC before I discovered a poor
solder joint on one of the caps for that chip. Look REAL close at your
PWB to see if you don't have the same problem.
Jacques Carrier
Thanks a lot for the tip Ken.
I resoldered all components around the vert. IC and the set is working fine!
Jacques
