NPNTEK
Hello Group:
Subject: Zenith SR2568S 27" TV
This set had two (2) initial problems ... not sure if they are related:
1. Loss of Green Color ... I was able to repair this problem by resoldering
some cold solder joints on CRT board.
2. If I turn the set to a channel above 39 (CH 42 for example), I can see the
channel and everything "seems" ok however, if I turn the power OFF - Then back
ON, the same channel will be selected however, all I see is "snow" (blank
raster). If I flip down to a lower channel (CH 3 for example), then go back to
CH 42, it works (can see the broadcast)
I noticed that when I set up the Channels (via auto channel routine from the
menu) the channels that cause trouble (e.g., CH 42) are not "found" during the
auto channel search.
I would really appreciate any repair info that you folks can offer!!
Regards,
RJ
Regards,
RJ
