Lots o' tips! Pull the 9-1302 module and add 1 pound of solder!
Text pasted from WinSTIPS 2.0
http://www.ServiceSoftware.com
ZENITH 9-1318
Loss Of Convergence, Bowed In On Sides, Picture Pulsates
Marshfield Tv
Check Pin 8 Of Plug 7c3 For 26 Volts. If Missing, Check Solder On L3408 On
9-1302 Board, 26v Supply From Tx3402 Pin 8. Whole Module Eat Up With Bad
Solder Joints, But That Was The One Causing This Problem.
ZENITH 9-1318
Convergence Bowed In On The Top And Bottom / Pix Pulsates
Dick'S Radio & Tv, Inc.
R4074 (27k@1w)
ZENITH 9-1302
Convergence No Go
Shorted Diode Cr3206 Open Rx3210 By H.O.T.
ZENITH 9-1302
Convergence No Go
Doug - Vision Video Labs, Inc
Replace Open Rx3210 Off Pin 10 Of Flyback Killing The 16v Supply To Ic4503
ZENITH 9-1302
Convergence Out, Picture Bowed And Pulsating
Gary D. Bombard Action Tv Systems
Soldered Connections All Over Board And Especially Around Connectors Ch21,
Ch32, Ch33. Also Soldered Main And Convergence Power Boards.
ZENITH 9-1302
Marshfield Tv
Check Pin 8 Of Plug 3c7 For 26 Volts. If Missing, Check Solder On L3408,
26v Supply From Tx3402 Pin 8. Whole Module Eat Up With Bad Solder Joints,
But That Was The One Causing This Particular Problem.
ZENITH 9-1302
Video And Osd Lost After Warmup. Audio Ok
Jeff Stielau : 11/26/02 : Shoreline Electronics
Cracked Solder Connections Smps/Sweep Module. Tx3402 Pin Had Burnt/Heat
Stressed Connection. Scrape Away Copper Trace Next To Eyelet & Resoldered
Really Well For Good Connection. Cracked Solder Connection On Qx3201 &
Vertical Yoke Pins. Go Over Chassis Really Well
ZENITH 9-1302
Video Bad, Loss Of Sync, Dark Pix, Etc., Problem Could Be Intermittent
Marshfield Tv
This Set Usually Exhibited The Problem After Short Warmup, But Sometimes
Played All Day With No Problems. Traced Fault To The Pip Module (9-1237).
Could Aggravate Symptoms By Heating And Cooling Surface Mount Transistor
Located One Inch Down From Top And 1/2 Inch From Left Side (As Viewed From
The Rear, Chassis In Set). Have No Idea What Orig Part # Was, Replaced With
Nte2407 And All'S Well.
Jeff Stielau
Shoreline Electronics Repair
344 East Main Street
Clinton,CT 06413
860-399-1861
860-664-3535 (fax)
[email protected]
"If you push something hard enough it will fall over."
Fudd's First Law of Opposition - Sir Sidney Fudd
