Rejean Nadeau
I HAVE THIS SET FOR REPAIR, WHEN TURNED ON THE SET HAS HV WITH NO
PICTURE AND SMOKE WAS COMING OUT FROM UNDER THE P.C.B.
WHEN I LOOK AT THE PCB I SAW THAT SOME SORT OF LIQUID HAVE BEEN
SPILLED INTO IT. I HAVE CLEANED THE P.C.B ON BOTH SIDE IN THE HOT
AREA. I CAN SEE UNDER THE PCB THAT IT WAS BURNED BETWEEN TO TRACES.
I HAVE TRIED THE SET AND IT WAS WORKING GOOD, BUT AFTER I WHILE
ELECTRIC SPARKS WAS COMMING OUT FROM THE HOT AREA AND I CAN SEE SOME
LIQUID COMMING OUT FROM THE LIQUID COOLER ASSY(THE PREASURE VALVE IF I
CAN CALL IT THIS WAY) FROM THE BLUE GUN.
SHALL I REPLACE THE COOLER ASSY????
IS IT THE TUBE THAT CAME TO HOT????
CAN I REFIL THE COOLER ASSY???
WHAT PARTS ARE AVAILABLE????
