F
FyberOptic
I'm having some confusion regarding zener diodes which I hope somebody
much brighter on the subject can clarify somewhat, or at least point
me in the right direction!
The basics of diodes has always been "current can only flow one way",
and beginners are left to assume this means they'll always do just
that. But obviously that's not the case, since normal diodes will
stop doing such a thing if they're pushed too far, I understand. And
as a result, people take advantage of this effect more reliably with
the zener diode apparently, by making them "fail" at much lower rates,
it would seem.
So while this is possibly out of the scope of asking on a newsgroup,
what sorts of applications could they be used for reliably? I hear
they can be used as regulators, but only if the load is fairly
constant. So, for something like an electronic circuit, with chips
going on and off and constantly changing the load, would this be of
any use there? I've seen them used in situations such as when one is
drawing power from the PC parallel port. I'm assuming this isn't
related to actually getting that power, but keeping it from going too
high.
I'm curious because, despite my lack of knowledge regarding the
details of analog circuits, I have a pretty decent understanding of
digital ones, and find myself making and planning new things in that
realm all the time. I'd like to power some of these sorts of things
off of batteries sometime instead of a 7805 on an ac adapter, and am
interested in the best way to go about it. One project in particular
involves an 8052 microcontroller with an lcd which I'd like to make
portable, for example.
On a side note, how possible would it be to boost the voltage from a
couple of AA's to run 5v logic reliably? I can't really think of how
such a circuit would be made, though I know they surely exist. I
assume it uses capacitors and an oscillation of some kind, but I
dunno. When I think of changing voltages, I mostly just think of
transformers.
Anyhoo, any help or pointers would be greatly appreciated!
it would seem.
high.
transformers.
