Will you be using it primarily with the laptop running software such
as The Cap'n? If so, maybe a better way to go is to get a more
accurate GPS with the money instead of an extra display you wouldn't
use much, like the Raystar 120 NMEA, which is a Satellite Differential
GPS receiver, NMEA output data, built right into the antenna pod.....
http://www.raymarine.com/raymarine/ProductDetail.asp?site=1§ion=2&page=80&product_id=147
WAAS/GPS is so accurate if you waypoint a bouy you'll run right over
it. [... stuff deleted ... ]
For serious navigation in the fog, WAAS-GPS is the way to go,
now......3 meters worst case....usually much closer.
Forgive me for saying so, but I think this is crazy. For serious navigation
in the fog, a BRAIN is the way to go, backed up by whatever electronic
marvels may amuse you. But 3 meters vs 10 meters vs 50 meters shouldn't
matter.
Don't get me wrong ... I have a GPS, I love it, and I use it often.
But I cannot imagine putting myself and my boat into a situation where
I had to trust an electronic device for 3-meter position accuracy as a matter
of safety.
I maintain my boat fairly well, but I *have* screwed up once in a while. Back
when I first got it, I ran down the batteries because an alternator connection
worked loose .. and then my Loran (OK, it was sa while ago!) didn't help a lot
as I approached Portland ME with a fogbank rolling over me. My charts, on the
other hand, were pretty useful
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
. And I've known my laptop to go sneakers-up
just because it happened to feel like it. So I try to be sure not to lure
myself into any situations where a dependence on electronic devices is
essential.
I know Maine isn't Nova Scotia, but there tend to be some pretty good approaches
to dealing with thick fog. One is to anchor: by the time the wind comes up,
the fog's often gone (and if your anchor doesn't reach the bottom, you're
probably in deep-enough water). Another is to shut down the engine, listen,
and think. Sometimes you can even hail another boat whose GPS *is* working
and ask for a position. But the saddest thing I see in Maine is the guy
swearing at himself, his wife, his boat, the electronics maker, and everyone
else, because without a collection of devices that are far more complex
than the ones that took astronauts to the moon, he can't get to the next
harbor.
So here's the dirty little confession about my GPS: I mostly have it read
lat/lon; I record the position in my logbook, and on the paper chart. Shocking
but true.
-John
