E
ER
I would like to solicit help in reverse engineering a mechanically
scanned LED display that I've seen in specialty stores such as the
Discovery Channel store.
As far as I can tell, the unit operates as follows:
1. A column of LEDs sits on top of an arm made out of a springy metal
(dimensions similar to a hacksaw blade). The base of the arm is fixed so
the top of the arm with the LEDs can sway back and forth.
2. Just below the column of LEDs on the arm is a bulk of metal which is
probably a magnet.
3. The arm is positioned between two parallel electromagnet bars which
are about 6-inches in length. The bars are at the same height as the
bulk of metal on the arm.
4. There is a photo-interruptor positioned so it gets triggered by the
moving arm, and the pulsing of the LEDs is controlled by a microcontroller.
I imagine the thing works by energizing the bar electromagnets in one
direction and then in the opposite direction to create an oscillating
magnetic field. The field pushes and pulls on the arm's magnet making it
swing back and forth. The springiness of the arm gives the arm a quick
stop at the limit of its swing as well as helps to propel it on its
return swing. I estimate the frequency of oscillation to be in the low
tens of Hertz (10 - 20 Hz).
One thing I eespcially like about this mechanically scanned display is
that there are no gears to jam up if you forcibly stop the arm. Indeed,
it is safe to stop the moving arm with your finger.
I'm just a computer guy so the microcontroller stuff isn't a problem.
The questions I have relate to the design of the electromagnetic
subsystem. Specifically,
1. Does my theory of operation have a chance of working? After all, the
magnetic field along the length of a bar magnet is much weaker than at
the ends. Is it possible that the two bars actually form a U-shaped core?
2. What kind of parameters should I be considering for the design of the
electromagnets? If possible, I'd like to use something like a 12V/1Amp
power supply, although my prototyping suggests that this won't be
powerful enough. What about using an AC-powered (120V/60Hz)
electromagnet? Has the potential of killing two birds with one stone
since the oscilliation would be taken care of by the power company.
(Yes, I know it also has the potential for killing myself, although
there are AC electromagnets in many household appliances, so I know they
can be safely made.)
3. Are there any other considerations I should be aware of when
generating these fluctuating magnetic fields (such as telling friends
who have watches with expensive Swiss movements to stand back.)
All help will be appreciated,
probably a magnet.
