Hi Forum,
I have a similar dual rail PSU query to the chap asking about metering his negative voltage rail. I had posted to AllAboutCircuits also.
I bought a pair of YB27VA volt/amp meters, hoping to use one for the +ve rail & the other for the -ve rail, but I'm beginning to see that I maybe cannot use it on the -ve.
My PSU is very similar to the Visio-Jameco unit:
( http://www.jameco.com/Jameco/Products/ProdDS/20626 Manual Revision 3.pdf ).
Does anyone have any suggestions? Maybe I could get the -ve voltmeter working, but not the -ve ammeter? These meters seem to monitor the current flowing in the return connection rather than the supply wire.
I've pasted my original post below for info.
Many thanks & sorry for any duplication.
Simon B.
Ive made myself a nice adjustable voltage dual rail lab style Power Supply Unit (PSU); just a standard design using adjustable Linear Voltage Regulators (LM317 & LM 337 for the positive (+ve) & negative (-ve) voltage rails).
These regulators are rated at up to about an amp & will give me about +1.4v to +30v for the +ve rail, & -1.4v to -30v for the -ve. No adjustable current limit control, apart from the built in short circuit & over temperature protection.
Obviously it's not as good as something I could buy, but will be adequate for my circuits. Maybe a few extra decoupling capacitors would improve it further.
My question is about fitting volt meters & ammeters to it. It's easy to fit an analogue voltmeter & an ammeter to the +ve & -ve supply rails, but these 4 meters will take a lot of space.
I found these twin-colour digital modules (YB27VA seems to be the part), each showing voltage in red & current in blue.
I can see how easy it would be to put one in my +ve supply rail, but am not sure if I can ever put one in the -ve supply rail, as wouldn't I need to connect it 'backwards' to work? But would it work or get damaged?
Does anyone have any experience in these modules? It took a while to work out what to do with the red, black & yellow wires & the badly translated specification & weird trio of connection diagrams!!!. It seems the module derives its power form the test voltage, but only if its between 4.5v & 30v, & who knows how the one in the -ve rail derives its power from!
If anyone has any advice or suggestions, please let me know.
If I get it working properly, I shall put it in the Projects Section of the website.
Many thanks,
Simon Bond.
Sent from my iPad2:-
Simon.D.Bond MEng, BSc(Hons), IEng, MRAeS.
Simon B.
Many thanks,
Simon Bond.
