1996 Yamaha RX-V795a
I bought this receiver at a yard sale. Before buying I was able to test it. It powered up and I tested all channels and everything was working. The next day I tried powering it up and I noticed it would shut off right away in about a half second. I have another receiver that is the exact same model and it was having the same issue, the contact in the relay was worn and I just needed to replace it.
So i removed the cover to inspect the power relay switch and it does have continuity. The switch just doesn't stay on. Could the cylinder on the switch be bad? I don't wanna try holding it down and possibly burn something out. Is there any other components on this board that could cause of this problem? I don't have a capacitor tester, but I do have a multimeter.
