Yamaha EMX 62M : SAFETY NOTICE
N_Cook
Mixer amp
With age,humidity or temperature or whatever, the screening card lining the
inside of the plastic case can curl up and touch solder and traces on the
IEC sub-board, aluminium side to mains voltages. Cut away all around that
corner on the rear and side card.
The EMX 88S has proper rigid metal work around that IEC area
N_Cook
Mixer amp
For us folks on the west side of the Atlantic Ocean, what is a
screening card?
The lining put inside plastic cases to simulate metal cases as far as RFI
out or in , in in this situation.
(almost as good as the pub sign painter having to change the kerning
between the "Fox" and and and and and "Hounds").
Something like a composite of card and aluminium foil so high probability of
differential dimensional changes, ie curling
Whats it called over there and I'll add to
http://www.divdev.fsnet.co.uk/tool_terms.htm
David Nebenzahl
screening card?
Typically what you Brits call "screening" we call "shielding". I think
most folks here would refer to that as a shield of some sort (RF,
electrostatic, etc.)
N_Cook
So what we call a valve screening can would be a tube shield in the US ?
David Nebenzahl
Eggs-zactly. Just the way you call a "windscreen" what we call a
"windshield".
