E
ElectroNovice
I have a Yamaha amplifier that's about 5 years old. The right channel
is normal, but the left channel has a low hum and significantly reduced
sound volume/quality.
I've tried the following:
Switched speakers- Not a speaker problem.
Switched from A to B speaker output- no change.
Tried multiple audio sources and input jacks- Not a source or input
jack problem.
Tried headphones- Same results as speakers. Hum and low volume, low
quality sound.
Tried changing DSP program modes- hum stays the same in bad channel,
sound changes as it should in working channel.
Tried adjusting all knobs including balance- no effect other than as
expected.
Tried all switches off/on- also no effect other than as expected.
Notes:
The hum exists even if no audio source is connected to the unit.
The hum does not increase or decrease when I move the volume knob.
The tone of the hum changes when I switch into the mode that lets you
change the volume of five speaker output channels (front, rear, center)
and when I switch from one channel to another.
Adjusting the volume of channels otherwise has no effect.
I am a newbie to electronic repair but can read and follow directions
and am willing to use this amp to learn on. I don't have any test
equipment but would consider buying or borrowing it.
Any help would be appreciated!
Thanks-
jack problem.
quality sound.
expected.
Notes:
Thanks-
