I have assembled the circuit of XTR 117 on breadboard as provided on pspice.
Input voltage of 0-5 V is provided through variable power supply.(Positive terminal of supply connected to IN terminal via 33K resistor and negative terminal of supply connected to IRET.)
Supply voltage is 20V, load resistor of 100 E and BC 547 transistor is used and results are as mentioned below.
Voltage at pin no. 2- 0.15 V to 0.5 V (for 0 to 5 V input)
Voltage at pin no.3- 0V
Voltage across load resistor(100 E)-0.06 V (constant for entire input range)
Voltage at base terminal of transistor- 3.8 V (constant for entire input range)
Voltage at VREG terminal- 5.24 V (constant for entire input range)
Kindly check and suggest.
Thanks,
paddy
Thanks,
paddy
