It's actually a pretty rugged rig, probably the most reputable of the
mod-square inverters. I've heard of alot of Magnums failing, but no
DRs. They have, unfortunately, of late discontinuted their UL rating
for cottage/residential applications, which means they'd fail an
inspection by an electrical inspector if your installation required it.
I'd say the other negative issue was the non-digital interface for
setting charging rate and whatnot.
Truly, though, if I were you, I'd try to roll enough pennies to get
yourself an OutBack FX instead. True sinewave power, and rugged as hell
One thing to bear in mind as well. Most folks that get a DR have also
scrimped on the rest of the system, and have installed a fuse rather
than a DC disconnect (legal for 12v systems, gray-area in 24s) and even
while in "off" (not search) mode, have a slight draw, which over the
winter, has been known to kill small battery banks.
DJ
