No. Think about it as the vector diagram. With correct connection the you have three vectors spaced at 120 degrees. Reversing one phase gives the three positive peaks at 0, 60 and 120 degrees.
The motor is being dragged around by the voltage between two phases. This is normally root3 of the phase voltage. Reversing one phase gives entirely different phase to phase voltages, two of sin60 of phase and one of root3 of phase. The motor can only respond to the phase voltages applied, not what it ought to be. The motor will run very roughly, and if any load will not run at all.
Reversing the motor direction is done by swapping any two connections from transformer to motor, assuming the transformer is a correct wye connection. So if it is Aa Bb Cc then reversing is by Ab Ba Cc or similar.
You can get double wye transformers where by deliberately connecting the phases in normal and reversed order you can get a 6 phase supply which makes high power rectification and smoothing very much simpler.
