| Looking for a UK->US voltage converter either new
| or second hand. Needs to be capable of supplying a
| few amps. For an old piece of test equipment.
You gave no indication of the required wattage (few amps?), however you
might consider a builders site transformer. These are 240v to 110v with
the secondary winding centre tapped and taken to ground (55v between
ground and each of the two output pins).
They come in various sizes from 300watts up to several Kw, cased up and
often potted, usually yellow in colour, they are also quite cheap. Car
boot sales are a good source of second-hand ones.
Regards,
Harry (M1BYT)...
Remove the 'NOSPAM' in my email address to reply.
Free Amateur Radio Courses:-
http://www.ukradioamateur.org
