Hi there!
I'm building a frequency meter using as input a sine wave between 0.05V-0.55V (from a peak detector) and a frequency range between 5Khz-10Khz. I tried to change the sampling rate (I need at least 20Khz) to 76Khz (setting 16 prescaler from ADCSRA register), but the resulting data from ADC it's a constant (=255). I didn't find anything which could cause this constant output.
Having a higher sampling rate means that I could find more precisely the max amplitudes and then I could measure the time period between two max amplitudes resulting the frequency.
Any help or tips would be much appreciated! Thanks in advance!
The output: https://www.dropbox.com/s/jyguxpz8k18zsco/output.png?dl=0
The input: https://www.dropbox.com/s/94ou221vn89ndj0/sine_wave.jpg?dl=0
Code:
const int MAX_RESULTS = 256;
volatile int results [MAX_RESULTS];
volatile int resultNumber;
void setup() {
ADMUX = 0x20; // set A0 analog input
ADCSRA = 0xEC;// set 16 prescaler, enable ADC and interrupts and start ADC measurements
Serial.begin(115200);
ISR (ADC_vect)
results[resultNumber++] = ADCH;
if(resultNumber == MAX_RESULTS)
ADCSRA = 0; // turn off ADC
void loop () {
while (resultNumber < MAX_RESULTS)
for (int i = 0; i < MAX_RESULTS; i++)
Serial.println (results[i]);
//start a new conversion
resultNumber = 0;
ADCSRA = 0xEC;
