hi guys ive been trying to use the Mx29gl512f chip in my project. The data sheet is very confusing. I don't understand a number if things fir example ... when reading the silicone id u perform a read operation with A9 raised high z abd tge other address lines held low. but think about it what if say I want to read from sector 0 address 0200h?? is it nit the same as reading the silicon Id??... Now comes reading the status bits.. for you to know that a program operation had completed you read a status bit.... a normal read operation. . but NOTE when the system finishes programming it goes into read mode now if this happens and u perform a read you will essentially read a memory location not the status register. .. it also talks about a bit that toggles .... tell me this at what rate does the bit toggle I mean on off time.... gee its mess... anyone who's worked with this chip
Platforms
Content
