Hello,
I am fairly new to electronics, and I am trying to build a very simple crystal oscillator circuit, to use with some radio experimentation that I intend to do.
The simplest crystal oscillator seems to be the Pierce oscillator, and that is what I am trying to build. I've tried many different variations on the standard circuits, but I can't seem to get any of them to work.
The main circuit that I am trying to build is this type:
https://www.electronicspoint.com/crystal-oscillator-circuit-t240691.html
But as I said, I have tried several different variations, with different values.
The other problem is that I don't have an oscilloscope, I have hacked a PC sound card into an oscilloscope using the microphone port. It seems to be working ok, but I don't know how accurate it it, or if it is capable of measuring the 1MHZ crystal that I am using.
I am also trying to build the circuit on a breadboard, and I have read that is not a good idea for crystals, particulaly higher frequency ones, since they contain stray capacitance, could that be a problem?
I have built the circuit above using the following values:
Inductor: 3.3mH
Capacitor: 0.001uf, (1nF)
Crystal: 1MHZ
Resistor: 10M
Transistor: 2N5485 JFET
I am also using 2AA batteries, so 3V. Is there anything obviously wrong here?
Thanks for any help!
What I would like to know is if my circuit *should* be working with the component values that I have chosen, and if the problem might be hacked scope.
Inductor: 3.3mH
Crystal: 1MHZ
Resistor: 10M
