Hi all
I have a problem using the I2C module found within the WIZ C. I need
the clock (SCL) to be less than 100kHz. The manual says that there is a
constant named IIStretch that enables the user to elongate the Data and
clock pulses with the integer set by this constant. This is done
because as a default the WIZ C transmits data at 400KHz. Howewver, this
is not working since I verified with the WIZ C waveform analyser. Any
suggestions please?
Thank you
suggestions please?
Thank you
