Hello,
I have an electric bike and needed to replace the throttle. Out of the throttle there is a thin wire which contains 4 small wires (yellow, green, blue and red) going into a connector which connects the the battery power supply. I bought the exact same throttle part # on ebay but it turns out the wiring coming out of the throttle is not the same. There is a thicker wire coming out of the throttle this one containing 7 wires (red, black, white into one connector), (green and gray into another), and (yellow and brown into a third connector). The replacement throttles come in 24v, 36v, and 48v. The one I bought is 24v but the battery on the bike is a 12v? I'm confused... Can I use the 24v throttle I have which is the same except for the wiring? and if so which 4 wires of the 7 go into the connector? (i have a yellow, green, and red wire but no blue?).
