wiring color schematic (pinout)
Can anyone tell me where I might find the colors for the pinout on a Gigawear headset. I tried the company website but no luck. Any help would be appreciated. I am trying to wire a 7 pin din (using 5 pins) on the end of the cable after cutting off the USB end.
I can't help with the Gigawear.
The USB connection should be standard.
Look-up the USB pin configuration, and you should be able to find out which wires
from the Gigawear went to which function on the USB.
(You've got both wired ends of the cable you cut, so you can follow the wires to the
pins, right?).
Yeah, I think the Chinese are best at reverse engineering.
(But us Americans still try to give them a run for their money).
