Wiring a 9 Pin D connector for standalone Logitech sub-W
I have a Logitech X-230 subwoofer with 2 satellite speakers, one of which has a power switch and volume control. These satellite speakers attach to the passive subwoofer via a 9'pin D connector.
What i am trying to achieve is to connect the subwoofer to my mini HiFi system's single Subwoofer RCA.
I assume that this can be done, however I haven't dabbled in circuits for over 30 years so I need some help from this forum.
I have uploaded a file which I found online showing the 9 D pin wiring diagram and I would really appreciate it if you Wizzards out there could advise me how to wire this in order to bypass the satellite speakers and connect the RCA cable directly to the subwoofer.
Many thanks in advance for your advice and suggestions.
This should answer your questions.
Forget the potentiometers, directly connect pins 2 and 9 of the S-SUB to the stereo jack.
Add a switch between 6 and 8 or simply short-circuit these pins for permanent on.
Thank you for your quick reply Harald. I tried this but it didn't work. Are there any other pins that should be connected together?
Cheers,
Chris.
2 and 5 would seem to be the correct input pins for the RCA connector, inner to 2, outer to 5.
Bob
hello i'm new around here excuse me the english from google translator I would like a help from you with the correct pinout (9 pins) of the logitech x230 male connector thanks in advance thanks
