Wanted: Wireless led signal system
Status
Not open for further replies.
Hi. I work for an insulation company and we currently use a very crude system to notify the person manning the machine to turn it off (which is bad for the machine).
I was wondering if anyone knowns where to find a battery powered two way light indicator (hopefully led) system? Idealy a wristwatch type button youd push which would light up an LED outside of the house.
I thought of purchasing walkie talkies though that seems a bit excessive if just for the light indicator.
Thanks in advance. Drew.
davenn
just use the walkie-talkies for what they are ... probably much more reliable and at least you can get an acknowledgement from the person outside :)
Unfortunately the unclosed spaces would make a walkie talkie too bulku. Must be a wristwatch or arm band type thing that doesnt get caught on things
davenn
they do make very small walkie-talkies
I used to use them in days gone by when I was a telephone installer and moving through ceilings and under floors
Drew, you can use a DC 12 volt 10A relay wireless RF remote control switch transmitter + receiver.
The 10 amp relay can supply power to a light.
The transmitter is the size of a key fob.
Status
