Mark Kelep
Hi all,
I got a small shock (electrical and the other) while leaning against a steel
window frame while handling speaker wires in a house today.
The home is built with concrete walls and all windows are steel.
I measured around 100 VAC between either speaker wire wrt the window frame
with the amp on or off.
I was able to light up an LED too, though the current couldnt have been much
as I didnt use a limiting resistor and the LED didnt burn out.
What the hell is going on??
Hoping for some advice as to what to check.
Thanks,
Mark
Thanks,
Mark
