I'm new to using comparators, and I think I have an understanding as to how they work, but when I go from paper to real-world, I do not get the desired results. My goal is to use a 5v power bank booster board and a 1k and 2k7 resistor to drop the voltage to roughly 3.65v, such that when the battery (26650 Lithium) is above 3.65v a LED is on, and when the battery drops below 3.65v, the LED blinks using a reverse 2n2222a/capacitor blinker circuit. I have used a LM393P Comparator and a Texas Instruments 272 Opamp. I have had partial success with the 272, and no success with the LM393. I have included my circuit below. What about my circuit is wrong, what would be a better circuit, and/or what comparator or opamp would you all suggest using?
Note: The outputs as designated by my particular symbols are wired together, possible connections are denoted by broken lines.This statement is to clear up any misunderstandings.
