'Captain' Kirk DeHaan
I have an Air 303 wind turbine. Still working fine. My issue is it is
not high enough. It's only 15' off the ground although we are a few
hundred feet off the valley floor on the side of a mountain and have
decent wind flow. The actual "good" wind stream is about 15' higher. I
plan to build a single pole tower of nested/stacked sched 40 steel pipe
with a pivot arrangement at the bottom. The bottom will start at 3" and
end up at the required 1.5 inch pipe. 3 to 2.5 to 2 to 1.5. I am
looking for information on lateral forces I may encounter so I make sure
I have enough concrete at the bottom and a stiff enough pole that will
hold up to the gusts. My current thinking is a 15' section of sched 40
1.5 inch as the last step with the remaining steps in 5' sections.
Overlaps at the welds will be 1.5 feet. I'm looking at about 800 lbs of
concrete for the base set 5 feet deep. I have a C band satellite dish
that has not moved in 12 years with this amount of weight at the base
and a huge surface area even though it is mesh. Do you have any pointers
to tech/engineering data that might help and what do you think of the plan?
Any help appreciated
Kirk
Kirk
