Franc Zabkar ha scritto:
FWIW, the "J3" version isn't listed, but the B3 and C3 versions are:
http://www.ezoflash.com/adapters/tsop48d2/suported_chips.htm
FWIW, the following utility "clears block lock bits":
http://www.ezoflash.com/downloads/28FxxxJx.zip
The EXE file contains the text string, "Intel 28F640J3".
Have you tried the forums?
http://www.willem.org/cgi-bin/yabb22/YaBB.pl
- Franc Zabkar
Thank you Franc, my name is Franco (i'm from Italy) too!!
I read the forums (the Ezoflash too) but it seems that software for Ezo
(v. 0.97J) cannot handle this device directly.
Files must be splitted in sections and some settings have to be set
manually.
Besides, J3 need tsop56 adapter and layout of this adapter is not public.
In Willem forum i only found two other questions like mine, but no
answers. Last software release (for the new USB programmer from Willem)
seems to be able to write these flash chips but there is no tsop56 adapter.
I will search in all other directions.
Slang
