Hi, I posted before a while back, and after some people pointed how to ask a proper question (Thank you @dorke and @Harald Kapp), I took their advice and am back again.
From my last post: "I'm trying to create a control system for a rocket. I know, it's a big task. But basically all I have to do is set up a TinyCircuit to pull the pin on two solenoids at 750 feet up in the air which I have successfully simulated by getting a buzzer to beep after traveling 10 feet up my stairs. This will deploy the two parachutes and hopefully turn the rocket around where it will then be controlled by two motors attached to the respective shroud lines in order to control the descent."
I came up with this basic circuit that is intended to use the DualMotor TinyShield to drive two motors and two solenoids (6V) using a 11.1 V 3 Cell LiPo Battery. I understand that the solenoids could be driven with MOSFETS, but I feel like the wiring would be much simpler with the DualMotor. The motors and solenoids will never be running at the same time. With my basic understanding, the solenoids should draw .33 Amps because they are rated at 2 Watts and I am getting the 6V model. And the motors can each draw a maximum of .7 A. This should work because the DualMotor can output a max of 1.8 Amps at each output, right? However, in my current circuit design the voltage across them would be 11.1 volts, because they are in parallel. I have to decrease the voltage right? I was looking at linear voltage regulators and this L78 (6V output, 1.5 A max) seemed to fit what I wanted. If I put them into the circuit before the current splits into the two motors or the two solenoids, but after the motor driver, would that work? In all of this, the part that confuses me the most is the internal structure of the DualMotor. I look at this schematic and my head just explodes. There is an H-Bridge and some MOSFETS integrated within it, but is this enough? Do I just connect everything as shown in my circuit diagram and that is it?
Thank you for any help. <3
