Hi all, this is my first (of many, hopefully!) post here. I am just starting out with electronics and have a semi-novice knowledge of electronics.
I have a quick problem I could use some help with tonight.
I have 36 LEDs hooked up to an old AD/DC wallwort, and I notice it seems dim with a flicker. I *THINK* each LED is capable of around 20ma, and there's 36 of them.
Just a thought, but that would mean my absolute max current would be 720ma, a far cry from the 1/3 of that (200ma) it's using now -- which means if the LEDs are only getting 1/3 the current they want, that could cause a flicker.
My idea would be to put, say, 600ma through it and see what happens. I wonder if it will still have the slight flicker. Or, conversely, what if I put on 1000ma and gave it a resistor that downscales it to around that 600-something mark? Maybe that would better eliminate the flicker, because then it's not just freely letting all the current through... Because I haven't eliminated the wall wort as the cause of the flicker...
I should also note the wallwort is 12VDC, 200ma. I also have a 12VDC, 1000ma unit on deck that I hope to be able to put to good use.
Any ideas?
Any ideas?
