Wii U Component identification
i got this wii u for free and tore it all down. It seems like something was spilled on it at one point and now It doesn't power on. I metered out some fuses and components but there is component that seems to be the problem just by what I tested. The only thing is I don't know what it is. At first I thought it was a re settable fuse. It has 4 connection points. The neutral flows through the top Left point and out the top right. The bottom input pin is connected with vcc but does not flow through the component so I thought maybe it was a re settable fuse because of the way it looked. I will attach a picture to this thread. Help would be appreciated Thanks, Victor The component is in the blue square. Heres the link to the picture:
http://oi57.tinypic.com/v3mu01.jpg
Please upload the pic to the forums... The pic in the link is too small, and I got hit with redirects with ads when trying to view the 'raw image'
Additionally.. it's difficult to 'test' an unknown component if you don't know how it's supposed to behave.
Please get a nicer image, and use the 'upload a File' button on the forums here. (Right beside 'Post a Reply')
Sorry that is as good as I can get right now. I will try to take my own picture tomorrow with my high resolution camera then I will post again. Anyways just from what your seeing any ideas on what it is?
KrisBlueNZ
Sadly passed away in 2015
Based on the circuit reference, I guess it's a filter of some kind - probably a combination of small inductors and capacitors arranged as a pi filter or a T filter. For reducing emission of, and susceptibility to, conducted interference on the power cable.
Can you upload a picture of the DC power supply that plugs into the yellow connector, or list the markings on it.
Input: 120v AC 60Hz 1.1A
Output: 15V DC 5.0A
I.T.E power Supply 12SK E176979
The power supply is new and does not have any blown fuses or is damaged.
Here are the pictures. It does look like the component is damaged.
davenn
I can desolder for a better look if you want. I was avoiding it though but its not any kind of pain to do
Well it looks like some one was hacking at it with a soldering iron
It's an inductor, more specifically a filter, its probably has 2 coils in it which means 4 contact points on the circuit board
why do you think this component if faulty ?
are you the one that has been at it with the soldering iron already ?
test with a multimeter in Ohms range between the 2 x A arrows and between the 2 x B arrows
should be zero or close to Ohms
Dave
no I didn't desolder anything on it if I was going to anyway I would use a hot air solder re worker. There was something spilled on this at one point and I think it might have destroyed that component. I just can't believe how people neglect thing like this. I'm going to desolder and test resistance like you said. Thats why I saw this as a problem because it looked like it was damaged and melted when whatever spilled on it. Anyways I just started learning about pcb and components like this in school so I was curious if you think this would cause problems with the power if its a filter for blocking out other frequencies like you said?
davenn
That's why I saw this as a problem because it looked like it was damaged and melted when whatever spilled on it.
OK no problems .... a valid thought :)
you can test it without unsoldering it ( keep the plugpack unplugged from the board, initially )
that's cool, great to see you getting into a new hobby.
it would ONLY be a problem if one of the coils was open circuit, hence why I asked you to do a resistance ( continuity) test on it
cheers
Dave
Well that was the problem after i desloderd it I crossed the pins and turned it on and it worked. Then desolderd the bridged contacts. i need a new part now what size do think this part is. Is there some kind of chart online i can compare my part to, to get the size. Also i don't know to much about inductors. When buying one I know I need a surface mount but would I get a 15vDC 0.5 amp inductor. Is there some kind of calculation I can do to figure out what i need using the resistance in the circuit.
davenn
you need to know the actual inductance of its 2 coils
the same physical size is almost irrelevant as they could all have different number of turns on the coils
meaning different inductances
I see no writing on that one to give any idea
Do you have an inductance meter or that setting on your multimeter ?
if so you could see which coil may still be OK and read a value
Dave
davenn
did you not go to the link Kris supplied ?
there's a whole mass there to choose from.
are you not in the USA with access to Digikey ?
