Joerg
Folks,
Got a need for FFT analysis. But it's got to be fast and wide, for
example a swath from 70MHz to 90MHz would need to be FFT'd in 500usec or
less. Meaning at a rate of more than 2000 FFTs per second. The
resolution doesn't have to be great, a 8192-point FFT would be fine.
Analog RF conversion could be done as well if it absolutely has to be
done. The frequencies and requirements will change but in essence that's
one of the jobs at hand.
The widest-BW SDR I found is this one, at 4MHz BW:
http://www.srl-llc.com/
Then there is Ettus but the Windows programming environment for those is
IMHO absolutely horrid. I have a Signalhound but somehow those no longer
seem to do super high BW fast scans. At least mine won't go past
3frames/second.
The best would be if the whole FFT enchilada could happen inside a DSP
or FPGA in the radio or analyzer, and only the results are ferried to
the PC via a USB link.
Is there something better out there? It can cost a kilobuck or more if
needed. But ideally not 10 kilobucks. Should run without fancy LabView
SW or the like if possible. What we need is basically a waterfall FFT
with adjustable rolling speed.
3frames/second.
