Wide band amp basics
Claus Jensen
I need to build a wide band amp for laboratory experiments.
Could someone with expertise in this area briefly list the design
considerations, trade-offs, etc. for the specs below.
I just need a starting point and idea of what can be practically
achieved without undue cost or complexity, ie. a common op amp and a
few transistors.
Specs:
DC to 10MHz, 100MHz if possible. Single supply operation. Prefer 12V.
Low impedance input, ie. sensor coil with suitable series resistor.
10W output into a resistive load. As much gain as I can reasonably
get.
Thank you,
Claus
Joerg
Hello Claus,
Check AD and other web sites for app notes. This is no big deal with
opamps anymore these days.
If you need a really stiff output you can use buffers. I bought a whole
lot of LH0063 before they became hard to obtain. These make powerful RF
buffers and go to DC.
Regards, Joerg
H
Helmut Sennewald
----- Original Message -----
Newsgroups: sci.electronics.design
Sent: Wednesday, May 11, 2005 2:35 PM
Subject: Wide band amp basics
few transistors.
Specs:
get.
Thank you,
Claus
Hello Claus,
What is the value of the resistive load?
If your resistor value is 50Ohm, then you need a much
higher supply voltage.
You should be aware of P=U*U/R
U is the effective value of the voltage applied to the load resistor R.
Best regards,
Helmut
Similar threads
