I have a tiny squirrel living in my basement. He's been there for months and it's time I get him outside safely. He won't go into a humane trap so I've drilled a 3" hole in the wall and put a ramp outside. I thought he'd go right outside the first night but no, he goes out onto the ramp many times a night, looks around for awhile but then goes back inside. I have a wi-fi camera outside pointed at the ramp to see these things.
My thought is to put a cat flap door over the 3" hole I've drilled and then use a wi-fi enabled A/C outlet---they are outlets that I can control online. That way I can be upstairs and when I see him on the ramp in the camera, I can send a signal to drop the cat flap. I'll use a cat flap/door that can only open in one direction so he can't get back inside.
What I can't think of is some device that then plugs into the wi-fi enabled outlet to allow me to send a signal remotely to then either apply power or remove power to drop the cat flap door into the closed position. Something like a magnetic latch that is powered by 110v electricity would work but I can't find anything like that.
I would appreciate any suggestions (but my little squirrel squatter won't). I'm not able to build anything so hopefully someone can think of some device I can buy that will plug into the wi-fi enabled outlet to allow me to release the cat flap.
Thanks very much.
Thanks very much.
