My r/c controled snow plow stopped responding to commands. No up or down, left or right. I used a small clamp on multi-meter to check out voltages(ok), grounds(ok). While looking at the wiring I set the meter near the receiver(which is entirely encased in a block of resin). I was giving up trying to find the problem when I tried the control for the heck of it. !!! The plow operated like new!! Bottom line: when the meter is on voltage and placed near the receiver the plow works. My question is WHY? Anyone know of a possible permanent fix. Some sort of circuit I can put together. An Arduino library? I find it hard to research because I don't know what is going on with the plow and the meter. Any suggestions will be much appreciated . Thank you
Platforms
Content
