Yea, I'll post some pictures, but don't expect to get anything out of them. I desoldered a few of the wires here and there, and even when they are soldered I just rely on bending them in the right shape so they don't touch, so it's confusing what's going where. To make it even more confusing they do generally blink when the wires touch like if the filter outflow from the aquarium is hitting one of the wires, but this time they weren't touching I made sure, the whole thing was on my lap while I was soldering it.
@BobK thanks, I wasn't sure if that was for the current or voltage, so basically if I don't draw more then I should then I could use my laptop power brick which puts out 19v at 7A? I just have to make sure I get the ristors right?
Edit: So I used the laptop supply just like BobK suggested, and the remainder of my leds went out completely, like they won't even light up with a multimiter. I'm not sure what went wrong, I plugged in the numbers right, 19v out, running 2 leds at 3.3 each thats 19-6.6 = 12.4, then I needed the 317 to do 1.5A so I divided by 1.5 and got 8.2ohm, so i wired 9 1ohm resistors, and the whole thing went up in flames.
edit: sigh, nope, they're all dead now. All 6 of my leds. While were on the topic, is it safe to have a CFL floating an inch above water? I made sure there are splashes, but can the moisture crack the glass or something, my other aquarium have cfl I dropped the whole hood in the aquarium a few times but they didn't explode or anything. Since this thread is dead I'll post up pics anyways, and myable I can get general suggestions, on what to do better in my system, how to wire better etc.
the last one above is a co2 diffuser that I built using a brushless motor and an arduino, I had it on for about a week now non stop and it seems to be fine, but is there any possibility I can electrocute my fish like that? Will it wear away the motor eventually from spinning underwater? I'm running it at 5v.
Also, do you see the heatsink in the 3rd image that the 317 sits on? I usually dangle the bottom of it in the tank since it overheats by a lot, sometimes it submerges completely with the chip for a few hours. It actually runs much cooler fully submerged, but again I was wondering if I can electrocute my fish like that and if it will cause it to wear away?
