i want to know why celllular phone are called so and other details like
what is bluetooth, gprs gsm there advantages and disadvantages
There were mobile, and even portable, phones before cellphones came along.[email protected]" ([email protected]) said:i want to know why celllular phone are called so and other details like
It involves refraction. Lower frequencies (longer wavelength) passKingcosmos said:<<If you're in area A,
someone across town in area X can use the same frequency because the
frequencies are high enough in the radio spectrum so they won't travel
far,
and the power levels additionally limit the range of the signals.
Maybe I misunderstood, but this seems to imply that higher frequencies
have inherently short distances in which they travel. All things equal
(environmental conditions, amplitude, power) does a low frequency
physically travel further than a high frequency? I would figure it
would be signal strength at distance X that comes into play. Can you
comment?
around obstacles that are much smaller than their wavelength with
little loss or reflection. When a wave encounters an object larger
than its wavelength, it tends to be absorbed by the object, or
reflected by it, or some combination of those two. Little of it will
continue on behind the obstacle.
So, going straight up, the distance capability is pretty independent
of wavelength, except for atmospheric absorption and reflection at
some resonance frequencies. But along the ground, where the waves
propagate through trees, buildings and lots of other obstacles, the
short wavelengths get lost much closer to the source.
far,
comment?
