Hi
Have a cctv camera AHD 720p.
Question when i connect the AHD720p camera to a monitor no picture appear on monitor.
But when i connect the camera to a DVR the picture appear, what happening.
Thank for your help mrel
There are two different types.
PAL and NTSC.
Depends which country you are in as to most common type.
You need to supply more detail on the camera, monitor dvr what plugs you are using etc. etc.
PAL and NTSC.
yes monitor have yellow input when using yellow video input no picture from camera ,but when connect camera to DVR get picture.
Is it because the camera is a AHD 720p camera?
mrel
AHD is analog high definition. Have you tried plugging in a cam corder to the RCA’s.
They may not accept analog signal. Which is why you would need a video to vga converter.
On the other hand, you are selecting the right signal source on the monitor??.
As you have not answered my question yet in my first reply. It’s difficult to say.
Myself and @Bluejets both asked “what monitor is it?”. Only then can we help you further. Or Google your monitor model and find out what inputs it supports. But I suspect more hardware is needed to convert the camera signal to that of the monitor. In which case is a VGA converter of sorts. There are many online. I bought mine from Radioshack/Tandy years ago. But Ebay has plenty in different formats/connections.
