Who's right and who's wrong?
before looking at the screenshot...
does a BMS control/regulate current when cells are stacked in series?
Without looking up a standard response...... I would take Battery MANAGEMENT System to mean anything between simple monitoring to full protection and control depending on how that system is offered up. I wouldn't expect BMS to mean a specific means of control.
Consider either approach - per your attachment - to be acceptable, no right or wrong.
I disagree, I can't find a single bms that current limits, it only cuts it off it exceeds the max current rating
if a cell approaches fully charged, it switches off that cell, there's no mention of the bms taking care of the current limiter...
if it did, people wouldn't buy specific chargers you would hook up you 15v and off you go...
Isn’t a charger and BMS completely different circuitry?
With charger limiting the total current and the BMS monitoring each cell (balancing).
When integrated they would indeed monitor, sense and current limit.
Martin
but they don't limit current in the sense that a current limiter does, if over current occurs the fet go off, current isn't reduced same goes for charging it, you decide current draw just don't exceed the bms rating...
how else do I get decide to charge at 5amps or 10amps with my lifepo4 (with bms) battery... or up to 25ampers but if I exceed it, it does /not/ limit it to 25 amps, it gets turned off until the current drops again
I agree.
I charge at 1A or whatever I choose with my bench PSU.
Martin
A fuse is a current limiter. Exceed the current and it cuts it off, true, but it IS a limiter.
When you say "a current limiter reduces the current" it actually does no such thing. It stops it rising past a certain level - there is no 'reduction' at all.
a fuse is a switch as well, it's fully on or it's fully off, there's no current regulation
if you are referring to a bms, consider it a switch, it doesn't reduce current it over current occurs, it switches off until you reduce the current...
you don't have current limited power supplies you have switch mode power supplies because it's either on or off, so unless there's resistance involved it's a switch
