Who manufactures RJ-45
RobertP
Hello everybody,
Maybe someone knows who manufactures multiport RJ45 _10-contact_ modular
jacks (not the plugs)?
Here is a sample board that uses something like that.
http://www.moxa.com/product/Multiport_Serial_Boards/PCI_Boards/CP204J.htm
I found that ERNI makes single-port ones. And this is the only company I
found so far. This is a little strange, since there is a lot of cables
and adaptors on the net with RJ-45 10-contact plugs (maybe it is
difficult to find something relevent in google because of that), so
someone must manufacture it!
dont know
RobertP said:
Hello everybody,
modular jacks (not the plugs)? Here is a sample board that uses
htm
company I found so far. This is a little strange, since there is a
lot of cables and adaptors on the net with RJ-45 10-contact plugs
(maybe it is difficult to find something relevent in google because
of that), so someone must manufacture it!
did you actually see this board?
RJ45 is a 8 pin spec. did not know it was changed to 10-pin option.
I have used 4jack RJ45 assemblys, but always with 8 pins each.
W
Watson A.Name \Watt Sun - the Dark Remover\
RobertP said:
Hello everybody,
Being that most network cabling uses only 8 conductors, it's a wonder
that _anyone_ makes jacks with 10 pins.
Try comp.dcom.cabling for some other informed opinions.
W
William P.N. Smith
"Watson A.Name \"Watt Sun - the Dark Remover\""
They are used on multi-port serial cards, which tend to need more than
8 lines, but they are hard to come by.
Ross Herbert
The 10P10C connector is known as RJ50
http://www.sacelec.com/pal/twist/1300dies.html
It is apparently made by Virginia Plastics http://www.vaplastics.com/
Send them an email.
Ross Herbert
|Hello everybody,
W
Watson A.Name - \Watt Sun, the Dark Remover\
We had two Bull minicomputers that sat side-beside. The two of them had
200 serial ports. Each port was a micro-D 9-pin, and there were 24
ports to a card. Talk about a mess of cables! And talk about an
expensive and difficult time finding cables or adapters for them. The
micro D 9-pin looks just like the 9-pin "DB" connector, AKA mouse port
on a PC, but it's much smaller. Using the RJ modular plugs and jacks is
probably a lot cheaper, since they're cheap plastic and easy to crimp
on.
http://www.molex.com/cgi-bin/bv/molex/custLogin.jsp?supplierPN=836119201
The one thing that gets everyone POed at these is that the clicker tab
snags on other cables when you're dealing with them in a mess of cables.
The ones with the protectors help, but then it's a bitch to get them out
of the socket when they're in a tight space.
