Who has a security system and dialup?
Terry
When my sister first got a computer her speeds were in the 40s.
Somewhere down the road she now only gets about 20k.
She was having trouble with one of her phones. I looked in her phone
box and the security people had put their lines on the main and the
extensions on their other pair.
Her phone problems turned out to be an inside phone. I am not sure
when her speeds slowed as it could have happened over the past 5
years
or so.
Has anyone confirmed that having a security system in the phone loop
slows dial up?
F
Frank Olson
years
or so.
slows dial up?
The "ringer equivalency" of all security panels is "0" (zero). When it
seizes the phone line your modem won't just "slow down", it will stop
communicating all together. The problem with your sister's line may
have to do with connections. I would suggest checking out the whole
house starting at the protector. Remove the wires from the terminal
lugs and (if you have sufficient length) cut and re-strip them. Clean
off any corrosion from the terminal lugs with a small wire brush. Wrap
the newly stripped wires around the posts and tighten the nuts/screws.
If the protector is exposed to the elements (subject to corrosion) you
might consider applying some petroleum jelly (or similar non-corrosive
lubricant) to the screw terminals after you've tightened them down.
Continue on inside the house and remove each of the phone jacks from the
wall. Restrip the wires and tighten all the screws. Check to make sure
the pins inside the connector are making solid contact with the phone
plug. A loose connection will degrade the performance (and cause
"noise"). Make sure the phone cables to the modem aren't routed around
(or near) any high voltage devices. Last but not least, check the
"ringer equivalency" of all the household phones. Add all of them
together and if the total exceeds 2.0, consider unplugging one or two of
them. If it exceeds 4.0, you may have problems getting your phones to
ring properly.
