I need a source of white noise (audio). It doesn't have to be perfect.
I seem to recall that you could use a zener diode as a white noise
source. Is this true? Are there any other possibilities? I anticipate
using a 9-V battery for my power, and a few transistors to amplify the
signal to drive earphones.
You may ask, "why the heck would he want to do that?" Good question:
http://en.wikipedia.org/wiki/Electronic_voice_phenomenon
Since I believe that the chances of there being anything to this are just
about zero, I don't want to invest a whole lot of effort in doing it.
Download my Daqarta software... it's free for signal
generation use. Midway down the Generator dialog, click the
left Waveform Controls button. Click Wave on the dialog that
appears and select Noise: White. Toggle the Generator
button on in the main toolbar. The first time the Generator
goes on the volume control dialog will pop up, plus a
cautionary message about loud levels. You'll need to cancel
the message before the sound starts. (In WinXP you may also
need to unMute, at the bottom of that dialog.) Later, you
can open the volume dialog via the F9 key at any time.
Now I'm going to give away a secret: In the next version of
Daqarta (v7.00, in a month or so) there will be a whole Help
section on EVP-related stuff, and a demo on how to hear it
for yourself. Well, not exactly what the woo-woo folks are
talking about, but a phenomenon I call "Phantom Signals"
that I think is at the root of the EVP nonsense... as well
as "dental radio".
The trick for phantom signals is to use headphones and put
the white noise in *one ear only*. The loudness should be
about 30-40 dB above your detection threshold. (You'll need
to be in a fairly quiet room, with no music, TV, or voices.)
I'll provide a simple way to set that level. Let me know if
you want me to explain a manual approach here. It's not
super-critical, but it needs to be loud enough to hear
easily, but not too loud.
Listen for a few minutes, and you will start to hear a
"radio station". You might hear music or voices, but you
won't be able to tell exactly what the song is, or
understand what they are talking about... nevertheless
you'll be convinced there is a "signal" there. You might
categorize the station as "Country", or "Talk Radio", or
whatever, based on what you hear. You'll probably have an
overpowering feeling that if only you could just improve the
S/N a *teeny* bit you would understand everything. But you
can't.
And if you switch the noise source to *both* ears, the
phantom signal vanishes and you just hear noise. (Sometimes
you can get the effect with both ears, but it may take a
*lot* of listening.)
I actually discovered this a long time ago, while designing
a diode-based noise generator. Since that sort of circuit
involves a lot of gain, when I heard the "radio station" I
naturally assumed that's *exactly* what it was hearing. I
tried all kinds of filtering before I finally got rid of
it... coincidentally having switched from a single-ear
lineman's test set to stereo phones. Problem solved!
Then I built a completely digital version, which doesn't
involve gain and is not susceptible to AM pickup... or so I
assumed. Yet it was back again, but only with the mono
headset, not stereo or speakers. Took a lot of testing to
convince myself that it wasn't a circuit problem... at least
not in my hardware circuit, only the "wetware" between my
ears!
Then when I showed the phantom signals effect to others they
were absolutely convinced it was a real radio station, and
that there was some defect in my hardware. Had to go
through all the steps with them to prove it was only in
their heads. The really convincing proof was that it
vanished instantly when heard through both ears... hard to
explain if it was AM pick-up!
For a long time I didn't want to announce this to the
general public because I hoped to recruit subjects for an
unbiased test. But that got put on the back burner for so
long that I've given up on it.
So enjoy!
Best regards,
Bob Masta
DAQARTA v6.02
Data AcQuisition And Real-Time Analysis
www.daqarta.com
Scope, Spectrum, Spectrogram, Sound Level Meter
Frequency Counter, FREE Signal Generator
Pitch Track, Pitch-to-MIDI
Science with your sound card!
