whirlpool washer
jeanie
i have an older whirlpool washer that has suddenly decided to agaitat
and drain at the same time. any help would be appreciated in fixin
this
Meat Plow
i have an older whirlpool washer that has suddenly decided to agaitate
and drain at the same time. any help would be appreciated in fixing
this.
Try asking this in alt.home.repair.
Without knowing how old and the model it could be hard to tell but
on the very old ones I worked on we had that problem when there was
a problem with the wig/wag coils that were mounted on top of the
gearbox. The wig/wag's were 2 solenoid coils that rotate with the
agitator and lift some pins to operate slides to change the gearbox.
If your washer has these coils there, check the coils for continuity
as they go open or if U are lucky the split pins could be broken or
worn out. If it is the split pins replace them with the correct pins
from a spare shop as they are hardened pins not the standard mild
steel.
Ken.
James Sweet
this.
If this is a conventional toploader, look in the back to see if it has a
wigwag, this is a bar with two solenoids mounted to it which oscillates back
and forth with the motor running. I've had a wire break going to one of
these and that caused a problem similar to this, as I recall in my case it
wouldn't shift into spin but the other solenoid controls drain IIRC.
jeanie
steel.
Ken.
Posted with NewsLeecher v3.0 Final
* Binary Usenet Leeching Made Easy
* http://www.newsleecher.com/?usenet
just wanted to say thank you will let hubby know! he said he though
that it might just be that. he's pretty smart about these things,
just got upset, cause laundry is piling up
