Where to get 4 pin to 2 pin 3.5mm adapter
I have a lapel microphone that has a 4 pin male 3.5mm jack on it and I want to use it with a car stereo that has a female 2 pin 3.5mm.
So the adapter would need to be 4 pin female to 2 pin male.
I've searched for an adapter online but it is difficult to search for this type of thing...many false hits. Cannot find one.
Anyone know where to get this?
A 4 pins 3.5mm plug has mic, left earphone, right earphone and ground. Instead of trying each pin to see which one is mic then I would cut off the 4 pins plug and replace it with a 2 pins plug.
The mic is probably an electret type (not a dynamic type) and the car stereo is probably expecting an electret mic.
The car stereo is probably expecting a line level input. Unless the input is labeled "microphone" a preamp that supplies power to the microphone will be required; not just some connector change.
