I'm struggling to understand this. Two questions that are stumping me:
4. It would be much easier to do the processing on
the silicon, e.g. by high temperature diffusion.
Buy a doped wafer and apply what you need to the surface,
and then cook it on that side. Vacuum metalizing is easy if you
sputter, as is chemically applied silver (Brashear process).
Several people have recommended buying a wafer. It was my impression
that at the microscopic scale even undoped silicon has relatively low
resistance. Perhaps I'm wrong. Anyhow, lets use the simplest
semiconductor, a diode. Could someone _please_ tell me how a schottky
diode is made on a doped wafer? It appears the recommended method is
to somehow etch a long thin _hole_ into the wafer and then deposit
metal into the hole to make the metal contact-- imagine shoving a thin
metal plate sideways into the doped wafer. Then etch two similar holes
on the outside of that and deposit the ohmic contact material, thus
forming a schottky diode. Perhaps etching is easier than I thought.
Anyhow, that's one simple diode, but how would multiple components
work on the same doped wafer then the doped wafer itself has low
resistance-- It would short out the entire circuit. I'm guessing that
doped wafer would not work, which leads to buying an undoped wafer and
using evaporator deposition (by heating the material in a vacuum) to
make the doped areas. Both of these methods are different since it
makes the junction plates vertical. My initial plan was to make the
junction plates horizontal. Etching such thin vertical hole sounds far
more difficult than simply depositing the plate materials on top of
the surface. Any thoughts and recommendations would help a lot.
My second question is, if a polysilicon undoped wafer is purchased,
and a small area (say 3um x 3um) is coated with ohmic contact
material, followed by a similar metal contact coating, and followed by
a similar silicon coating, all by means of evaporator deposition (by
heating the material in a vacuum), then would the deposited silicon be
polysilicon or amorphous? The goal is poly or mono crystalline
silicon, or better yet GaAs. The thought is that since the wafer is
polysilicon, then the metal atoms would convey the crystal structure
to the deposited silicon. Perhaps it would help if the evaporator
deposition process is slowed down, or perhaps chilling or heating the
wafer. Perhaps it would help if the coating depths are thin, on the
order of a few dozen nanometers.
Thanks,
Anon
