Where to buy 1500uF 6.3V 8x15 or 8x20mm low ESR/imp capacitors?
tomhoo
I have some 8x15's failed on a mobo and I can't find this size
anywhere. The closest is 8x20. However, Digikey and Mouser don't
stock them.
Lead spacing P=3.5mm
Maybe I should forget about trying to match, get a 10x15 P=5 and do the
best I can.
I'm guessing that the 8x15x3.5 was wishfull thinking when they built
the mobos and nowadays cap manu's realize they can't make that package.
Thoughts?
Tom
Andrew Rossmann
[This followup was posted to sci.electronics.repair and a copy was sent
to the cited author.]
stock them.
best I can.
Is there an issue with the extra height (.200"?) If not, get the
longer ones.
You can try checking manufactuers such as Nichicon, NIC, and Nippon
Chemi-Con/United Chemi-Con. Look for part numbers, and then try to find
a source for those.
