where is low cutoff for simple LM317 or LUXEON circuit?
i'm starting a new flashlight building hobby but i'm not too circuit
savy
question about the LM317 current regulator with a current adjust
resistor running a Luxeon LED.
At what low battery vogtage will the LM317LZ stop functioning and will
it draw little or no current ?
I read one that listed the range as 3-32v but other suffixes did not
list a min voltage.
the point is to prevent battery level from dropping when at this level.
At what battery vogtage drop will a LUXEON stop functioning and will
my plan was to hook it up and see then if not, try a potentiometer to
find the cutoff point?
can a simple voltage cutoff be made to to open the circuit
or a divider with high value resistors adjust the LM317 or LUEXON
cutoff with real
almost no curent? like micro amps..
then it occurs to me that someone probably knows the answer to all this
so if you've done it how did it turn out?
E
ehsjr
savy
The LM317 requires a minimum of about 3 volts higher
input voltage than output voltage.
Ed
