From an advanced in years newbie. Two images below are of a simple board that controls my favourite recliner. The lower switch (nearest to the 7 pin plug) is defective - the rest seems to function OK but I do not know the type of switch to get a replacement. It is a 'press and hold' to activate the retraction of the chair. The four pins seem to be linked to each other on either side but do not connect when switch stalk is pressed. The upper switch is similar but gives continuity across the two sides when pressed and, surprise, surprise, operates the extension feature satisfactorily.
The simplest solution seems to me to be to replace the whole board but I do not have a supplier name for it. If you can help I should appreciate it so I can get out of my recliner gracefully instead of tipping the whole chair!
