So on another thread I am looking for help to find out what component are causing a misfire with my car.
I managed to swap over two Mosfets, a 32 pin surface mounted chip, a 15 pin Fet looking thing from a donor ECU board.
(None of those parts made any difference to the misfire of the engine).
So tonight I come home and remove another 15 pin Fet looking thing, put it in the ECU and the engine does not start. Then I freak out and put the original part back in, and the engine will not start with that either...arghhhh!!!
I guess I must have overheated the part when I was hot airing it off the board??? I find that strange because I was able to remove other parts using the same technique and they did not get cooked and have worked fine, then this happens.
So I have managed to find a website that lists the components and they give a basis quick description of what they are used for int the circuit. The problem is that they are from China. How can I find a new component that will be quicker than 5-20 postage time???
These are the only part numbers that I have managed to find so far.
66285
55199 - this is the one I cooked by the sounds of things.
09380232
16205799
42827
16212886
This is the one I need.....
https://www.vipprogrammer.com/index.php?main_page=product_info&products_id=2107
66285
09380232
16205799
42827
16212886
