Hi:
What will happen if an analog signal is passed through a DAC [Digital-
to-Analog Converter]?
Assuming you are talking about a multiplying DAC,
you will essentially have a digital volume control
for the analog signal. The problem is that it
will have a linear control range, not a
logarithmic ("audio taper") range.
To do this, you use the analog signal as the
reference voltage of the DAC. Note that not all
DACs (and not even all multiplying DACs) can
handle a bipolar reference. If yours can't, you
just need to add the appropriate offset (and
subtract afterwards), or AC-couple the signal and
sum it with the normal reference so that the sum
runs between 0 and the positive supply.
Best regards,
Bob Masta
DAQARTA v4.51
Data AcQuisition And Real-Time Analysis
www.daqarta.com
Scope, Spectrum, Spectrogram, Sound Level Meter
FREE Signal Generator
Science with your sound card!
